Monitoring Blue Prism robots from Mobilephone
MarkusPulliaine
Hello all,
Does anyone know is it possible to Monitoring Blue Prism robots from Mobilephone? 🙂
With best regards,
Markus
Markus Pulliainen
MarcinDabrowski
Hello Markus,
Not sure if you have it as part of your BluePrism package, but the company offers BluePrism Conenct/Hub that allows you to set up an internet / intranet based solution that provides you realtime info (configurable dashboards) of your robots utilisation, queue management, logs/exception monitoring etc.
You could then open the link to the Connect Hub on your mobile device/smartphone etc.
Hope this helps.
BW
Marcin
Marcin Dabrowski
Software Automation Development Lead
Moorfields Eye Hospital NHS Trust
PritamPoojari
You may want to look at following solutions on DX
https://digitalexchange.blueprism.com/dx/entry/3347/solution/appian-integration
https://digitalexchange.blueprism.com/dx/entry/9377/solution/rpa-supervisor-6
Pritam Poojari
Solution Architect
Capgemini
MattPalmer
I built a PowerApp that I connected to our replicated BluePrism database that allows my team to see which processes are currently running, how long they've been running, were there any process terminations, are there any schedule failures, what's in queue, how many transactions processed today, etc.  Not quite the full experience of what we can do in the Control Room, but it provides enough info remotely to know if things are doing ok and if I need to go get to my computer.
Matt Palmer
Business Process Specialist
Chesapeake Energy
America/Chicago
MarcinDabrowski
Hello Markus,
Hope this helps.
BW
Marcin
Marcin Dabrowski
