Hi All,
Need Info regarding the PDD, ODI, SSD Documents, who will prepare these documents and WHY!!!...
What are the documents prepared by Developer??
-- Naveen
Hi John__Carter,
I gone through the link which you provided. But i what to know detail about What are the documents prepared by Developer??..
Thanks!!..
--Naveen
Hi Naveen,
Did you check the link that John__Carter provided you?
In the Delivery Roadmap.pdf it clearly indicates who creates what....
Initial Process Analysis
Created by – Blue Prism analyst or Blue Prism developer
Read by – Client sponsor
Approved by – Does not require specific approval
ect. ect. ect.: All important docs are listed there.
I can encourage you to use the search function in the document (Cntrl + F) and look for: Created By... this will point you already into the right direction.
Good luck!
