Not able to convert x-www-form-urlencoded (Postman) to WebApi
Rufus
Hi, anyone who knows how to "convert" my Postman POST command to BP Web api format?
In Postman, the keys are in Body as x-www-form-urlencoded.
Converted to CURL (it looks like this):
curl --location --request POST 'https://xxxx' \
--header 'Content-Type: application/x-www-form-urlencoded' \
--data-urlencode 'grant_type=xxx' \
--data-urlencode 'scope=xxx' \
--data-urlencode 'username=xxx' \
In BP Web api \ Request\ Body content \ Template, I have tried both format 'key1=[value1]'&'key2=[value2]' and JSON format like { "key1": "[value1]", "key2": "[value2]"} (Content-Type= application/x-www-form-urlencoded and application/json).
Both elternatives return HTTP 400 error (which is syntax error, I quess).
Ruben Gjelsten
Senior Analyst Service Management
SSV IIC RPA
30 REPLIES 30
@Jesus Jordan,
By entering a value for Common Authentication you're telling Blue Prism to handle the authentication when in fact you want to handle it yourself. Change the Common Authentication to None and then pass in the username and password as input parameters on your Get Token action. Then you can reference them in the request body.
Hi All,
I am facing the same issue.
Please find the Postman screenshots.
Could you please help me with this and show me how to setup the HTTP request to get the result.
Jishnu P Nair
Developer
Ey
Hi Shashank,
I tried the body format which you suggested but still I am getting the error,
{ "error": "Invalid request" }
Below is my API body format,
grant_type=[refresh_token]&refresh_token=[XXXXX]
whereas I tried it from POSTMAN, API working successfully with x-www-form-urlencoded content type, with below format,
grant_type:refresh_token
refresh_token:XXXXX
Trupti Pardeshi
Software Developer
Wipro
UTC
Trupti,
What do you intend to pass in grant_type?
Value of Data Item refresh_token
or string "refresh_token"
Shashank Kumar
Singapore
+6581326707
Hi Shashank,
Value of grant_type is refresh_token ("string"),
refresh_token:XXXXX
Thanks in advance
Trupti Pardeshi
Software Developer
Wipro
UTC
Hi All,
This worked for me.
Address URL: API End URL
Body : "grant_type=client_credentials"
Content Type : "application/x-www-form-urlencoded"
User name : Client ID
Password : Client Secret
Let us know if this helped or not.
BP Version : 6.10.1
VBO: HTTP Request
Jishnu
Jishnu P Nair
@Trupti
Please try as per suggestion from Jishnu. If it still doesn't work then I would suggest posting screenshot of your POSTMAN configuration here.
Shashank Kumar
Singapore
+6581326707
In postman, i'm able to execute the post request successfully with required headers & body (x-www-form.urlendcode. Please refer the above screenshot and also the code snippet of it.
But upon executing via BP web services, facing invalid username or password error. The below screenshots added have all the details mentioned in postman. But still it fails .... How do i pass the user name & password in the following path to make it work (BP > Webservices >Request/body/template)
Vijay.A
Did you get the solution for this one ? im also facing the same issue
Did you get solution for this issue? i'm facing the issue (userid& password) passing it in body content
