Process Trigger Points
SimphiweTshezi
Hi All,
Is it possible to create trigger points that will run the Bots (processes) automatically as opposed to scheduling them to constantly run checks for those trigger points (e.g excel file)?
Many thanks.
Simphiwe Tshezi
1st Line Support
Altron Bytes Managed Solution
Africa/Johannesburg
Simphiwe Tshezi Software Developer (RPA) Altron Managed Solutions Johannesburg
5 REPLIES 5
sutirtha.gupta
Hi Simphiwe,
You can create windows exe to monitor the file availability and upon received you can trigger the process using command prompt. Please check the guide for running process using command prompt.
Sutirtha Gupta
RPA Tech Lead
TATA Consultancy Services
Kolkata/India
Hi Sutirtha,
I really appreciate your assistance, thank you so much.
Simphiwe Tshezi
Johannesburg
HarshitRawat
Level 8
You can create a batch file which would continuously perform some operation ( For ex- If an excel file exists ) and then trigger the process using command line arguments. Out of curiosity i experimented with something similar and it worked fine.
Created one batch file , added to windows startup , and the script monitored one folder for an excel file. As soon i paste the file in that folder , the script triggered a test process
Harshit Rawat
Senior RPA Consultant
Your response is received with utmost appreciation, I'd definitely try it myself thank you.
Simphiwe Tshezi
Johannesburg
Hello, Which guide to refer for this to trigger process using CMD and batch file. I want to learn and experiment. Also if you have any sample can you please share. Thanks in advance,
Thanks & Regards,
Tejaskumar Darji
