11-01-26 07:13 AM
Hi Team,
I hope you are all doing well.
I am currently encountering a technical challenge with a process deployment and would appreciate any insights the community might have. While the process executes successfully and launches the browser without issue within Studio, I am finding that the browser fails to launch when the same process is triggered via the Control Room.
For context, here are the environment details:
Blue Prism Version: 7.4.0
Browser Extension Version: 7.4.0
Browser: Chrome
I have verified that the extension is active, but the behavior persists on the Runtime Resource. If anyone has encountered similar discrepancies between Studio and Control Room environments in V7.4, I would be very grateful for your guidance or any troubleshooting steps you might recommend.
Thank you in advance for your time and help.
11-01-26 12:40 PM
can you please share the application modeler and launch stage object studio screenshot..
11-01-26 01:45 PM
11-01-26 02:00 PM
Site URL is missing in application modeler , if you are not passing Site URL in application modeler then you have to pass in Launch Stage under path .
you can enter the site URL in application modeler, for example: https://www.google.com
12-01-26 11:34 AM
I have tried but still getting the same error
12-01-26 11:56 AM
can you please share the application modeler screenshot. it should work..
13-01-26 12:41 PM
This is something that we currently have on 7.3, Blue Prism confirmed a bug existed for this and that it was fixed in the next version. A little concerning to see it present on 7.4. Either way though we were provided with a "Browser Utility" object to workaround the problem.
I would upload here, but the forums won't allow file uploads. If you send me a message I'll happily email it over to you along with our slightly modified version to add some more useful functionality.
