Slowdown while using the Send Keys function
10-03-16 08:45 AM
I've been using BP for a report automation, and everything was ready for Production, but all of the sudden BP started sending the keys really slow.
No matter which application I interact with, BP is now sending the corresponding keys so slow that the process starts to fail little by litte.
Does anyone hace that problem? or know how to fix it?
It is critical.
Thanks and greetings.
10-03-16 12:51 PM
Making sure that UAC is turned off, and that the account has administrator rights might help you (weirdly enough - it has helped me before)
10-03-16 02:37 PM
Hi HoracioIf you have been in process/object studio for a long time you can sometimes see the memory used by BP (automate.exe) creep up. Try restarting BP to see if that improves the situation.
