Hi - I want to spy java swing pages. I am unable to do it. I have jre8 installed in my machine, I have enabled java access bridge also from control panel, and ran jabswitch.exe and copies JavaAccessBridge-64.dll to Blue prism installation folder, and in application wizard I selected external -64 bit but then I am not able to spy in java mode my swing application.
My issue is as soon as my application get's loaded it has login screen pop up, so I tried creating separate object for pop up but it seems it's not accepting.
In the past I have windows pop up very well. Please suggest solution for this.
