Spying problem
raja_subramania
Facing a problem in some of the systems - Elements spied in the application modeler as a part of process/ object studio cannot be identified if the process/ object is closed and opened again. Anyone experienced this before and has a solution? Thanks
It sounds like you need to change your attribute selection in Application Modeller so that attributes prone to change are no longer selected. The guides in the training section of the portal give some advice about which attributes to use for different application types.
