ASD01 Solution Designer Exam Preparation
Hello Team,
I'm starting preparation for ASD01 which is Solution Designer exam. So looking for some guidance and advice around the same.
-How to prepare for it?
-Which courses will be helpful for the exam from LMS?
-Is there any practice test available on LMS?
-Any other advice/suggestion/feedback/experience please share it here so it can help everyone.
Thanks & Regards,
Tejaskumar Darji
HarshitRawat
Level 8
Hi Tejas
Some points I can suggest you from my experience
Though it contains just 28 questions , but be very careful to not spend too much time in the first 10-12 questions which are generally time consuming as they ask you to analyze the long  flows , come up with some improvement points etc
Go through the Development best practices , Solution Designer guides as there would be questions based on even a single line in the guide
All the very Besst!!!!
Harshit Rawat
All State
