Citrix Automation
sidram.m
​Hi ,
How to automate the applicaiton runs in VDI/client machines.
Sidramappa Hunashyal
SA
Accenture
JukkaSalovaara
If you can only use an application through Citrix, surface automation techniques are usually recommended.
Jukka Salovaara
Solutions consultant
Digital Workforce Services Oy
Europe/Helsinki
sumire
Level 9
here are documents and training kits of surface automation
https://portal.blueprism.com/documents/standard?title=surface&category=All&lang=1382
they are useful, easy to understand
I learned with them
Mitsuko
Asia/Tokyo
Mitsuko
Asia/Tokyo
As Jukka mentioned, if you can't install Blue Prism in the same environment as the applications to be automated, then your only option is Surface Automation.
I would really recommend looking into installing Blue Prism in the same environment, as process development is much faster with less obstacles.
Carl Carter
Developer Program Manager
