I had a similar experience.
According to Installation video I entered Customer id as 'developer' resulting in license registration failure.
Even worse was the error message 'Invalid license key' was not enough to undetand the situation.
Review License mail and find Customer id in the message with a License file attached.
That is the right Customer id to be entered when installing Hub.
The Customer id is saved in the file appsettings.json file in LicenseManager directory.
Update the file and restart all web servers.
After then it should accept license key.
If you have thrown away the mail, you might find the customer ID by decoding the lic file using base64 decoder.
Hope you find it helpful.
Bohyon Hwang
Director
블루프리즘
Seoul
+82262033950
Original Message:
Sent: 08-29-2022 07:20
Subject: How does the Hub plugin license work?
I am trying to understand how the hub plugin license model works.
How can we use this license for multiple machines?
Do we need a separate license for each machine? Or can the same license work on other machines?
How can a user remove the license from an old machine and keep using the same license on a new machine?
Is there any detaidocumentation on this?
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
