Consolidation Exercise Issue
KevinLearoyd
Good morning
I have contacted Blue Prism Customer Support.
They have suggested while they look into it someone on here may be able to advise.
I am at the consolidation exercise on the Learning Edition platform and get the following message when I try to publish a Queue. Does anyone have any suggestions please? Blue Prism have extended my licence but this hasn't resolved the issue.
The requested operation is not permitted, because the license currently in use does not permit it. The maximum number of published processes permitted by the current license would be exceeded
many thanks
Kev
Mukeshh_k
Hi Kevin Learoyd,
it seems you already have exceeded the maximum number of processes allowed with the learning license - its usually 5 processes allowed for publishing/Learning license - remove some of your other published processes in order to run & test your current process- Use sub process calling instead from a published process and do not publish all of them.
https://www.blueprism.com/resources/learning-edition/
Mukesh Kumar
