Blue Prism Product
 View Only
last person joined: 10 hours ago
This community covers the core Blue Prism RPA product.
 Internal : Could not execute code stage because exception thrown by code stage: The operation completed successfully
Manoj Patidar's profile image
Manoj Patidar posted 11-29-2023 06:09
Dim startPoint As New Point(StartX, StartY)
Dim endPoint As New Point(EndX, EndY)
Dim size As New Size(endPoint.X - startPoint.X, endPoint.Y- startPoint.Y)
Dim capture As New Bitmap(size.Width, size.Height)
Dim g As Graphics = Graphics.FromImage(capture)
g.CopyFromScreen(startPoint, Point.Empty, size)
FullSavedScreenshotPath = OutputFolderPath & Format(now, "dd-MMM-yy hh-mm-ss") & ".png"
capture.Save (FullSavedScreenshotPath, System.Drawing.Imaging.ImageFormat.Png)
ScreenshotImage = capture
g.Dispose()
I am using above code to capture screenshot of the screen, where i am passing parameters startX, endX, startY, endY, OutputFolderPath.
this code was working fine for last couple of months but today when i run the bot got this error:
please help with this.
Thanks and Regards
Manoj Patidar
Jerome Santiago's profile image
Jerome Santiago
I worked on the code to capture screenshots, made some tweaks, and gave it a test spin and it worked from my end. It looks good now.
Dim ScreenshotImage As Bitmap
Dim FullSavedScreenshotPath As String
If startPoint = endPoint Then
    Exit Sub
End If
Dim size As New Size(Math.Abs(endPoint.X - startPoint.X), Math.Abs(endPoint.Y - startPoint.Y))
If size.Width <= 0 OrElse size.Height <= 0 Then
    Exit Sub
End If
Try
    FullSavedScreenshotPath = OutputFolderPath & Format(Now, "dd-MMM-yy hh-mm-ss") & ".png"
    capture.Save(FullSavedScreenshotPath, System.Drawing.Imaging.ImageFormat.Png)
Catch ex As Exception
    Error_Messages = ("Error capturing screenshot: " & ex.Message)
Finally
    g.Dispose()
End Try
Output:
