Regarding dialog flow connectors
18-04-22 10:46 AM
I'm new to blueprism. Can somebody provide the documentation about how to integrate the dialogflow connectors with blueprism.
Ankush Singh
Ankush Singh
5 REPLIES 5
18-04-22 11:42 AM
Hi @AnkushSingh
Here you have an asset from the Digital Exchange that can helps you:
https://digitalexchange.blueprism.com/dx/entry/9648/solution/dialogflow-api-v2-2
See you in the community, bye 🙂
Pablo Sarabia
Architect
Altamira Assets Management
Madrid
Pablo Sarabia
Architect
Madrid
18-04-22 12:27 PM
Hi Ankush,
You can refer to the dialogflow connector from Digital Exchange here: Blue Prism Dialog Flow Connector
Also, if you want to know more on this use case then I have a video uploaded on my YouTube channel for the same as well: Google Dialog Flow Chatbot Integration With Blue Prism
Let me know if it helps!
07-06-22 10:16 PM
Hi Devneet,
I went through your detailed youtube solution and really liked it. However, I don't prefer to use the RGNOK tunneling solution. Are there any other workarounds to that?
Also, have you you tried using the BP Dialog Flow connector. I'm struggling to understand how to use it.
Please note I'm trying to create a chatbot in Dialogflow CX and then for fetching the data from backend systems, I want to use a webhook. That webhook should call a BP process (which will then call the backend CRM APIs) and then return the data (paramters, message) back to Dialog flow as a webhook response.
Siddharth
siddharth jindal
sr mgr
encore
Asia/Colombo
Siddharth
siddharth jindal
sr mgr
encore
Asia/Colombo
07-06-22 11:24 PM
Hi Siddharth,
What I have shown in the video is a sample POC and for that reason I am using a tunneling service like NGROK. In an enterprise solution, you would usually have either an On premise server such as one created using Internet Information Services (IIS) for Windows or you can go for a cloud deployment using services such as Amazon Route 53 and EC2 instances if we consider AWS cloud platform for example.
Once the servers have been setup and the incoming IP addresses have been whitelisted, you can keep running your Flask code or any other server side language like NodeJS to keep the channel constantly open to create a communication between Blue Prism and Google Dialogflow. Unfortunately, I haven't tried the BP Dialog Flow connector as of now but I can tell you it will require a Google Service Account and the Google Cloud server here will host the channel for communication. For it's usage you might have to check the available documentations from DX Exchange.
WonderBotz India Pvt. Ltd.
16-10-23 02:28 PM
By using the above i cannot find the asset in DX. Can you provide the new link if its available in DX now?
If we get the BP Dialog Flow connector still we have to use the RGNOK tunneling solution?
Thanks & Regards,
Salman Shaik
Thanks & Regards,
Salman Shaik
