32 bit BP in 64 bit VDI
PrasunDas
Can we run 32 bit BP sw within a 64 bit VDI? If not what are the challenges? How can they be mitigated? Any reliable workaround?
Yes you can run BP 32bit in a 64bit OS.
Has this been tested and proven?
I am using BluePrism on my 64-bit system since day 1. It works fine, just like ANY native 32-bit software will run on 64-bit machines. The fact that it runs from within a VDI doesn't change a thing, but it will limit BluePrism to run only within the machine and will be unable to access processess outside the virtual machine.
