Activate Window is not working in Blue Prism 6.7.1
_Amlansahoo
Level 11
HI Team,
Activate window is not working in latest Blue Prism Version 6.7.1.
If I am trying to do activate using Navigate stage then it's not working.
I faced this issue in Blue prism 6.7.1
Steps :- Select any application window using win32 mode and try to activate it using Navigate stage.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
KaranSareen
Have you started facing this issue after migrating to 6.7.1 or it is a new development. I would suggest you to re-spy the element and see if it makes any difference.
Karan Sareen
Solution Support Engineer
Blueprism
Australia/Sydney
I have tried various ways but it's not working. I started getting it only in 6.7.1.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
