Application Modeller does not identify elements in centrix data solutions app
Paul
I am using application modeller to identify elements in the "centrix data solutions" app from the university course. The only elements it picks up are the entire login window, or the close button (X) in the top right corner. I can't for example highlight the staff number or password fields. Has anyone else encountered this issue? I am running on a surface pro with windows 10 OS. Using win32 mode in application modeller, although I tried the others too.
Thanks 🙂
Paul
5 REPLIES 5
KaranSareen
Hello Paul
Have you tried with other Spy methods e.g. AA, UIA, etc? Moreover, try running the Blue prism application with admin privileges (Run as administrator) and see if it makes any difference?
Karan Sareen
Solution Support Engineer
Blueprism
Australia/Sydney
Hi Karan, thank you for your reply. I tried all modes and the only one that selects anything is win32 mode, and that only gets the full window or it's close button (X), but not the child elements within it. I also tried to run as administrator as you suggested, but it idid not make a difference - I still encounter this issue.
Paul Duffy
Hi Paul.
Click on Identify dropdown button and select Open UI automation navigator from application modeler.
you have to check each element from left side tree element.
You will definitely get your required element.
Please let me know if need any help.
Nilesh
Nilesh Jadhav
Nilesh Jadhav.
Consultant
ADP,India
Thanks Nilesh, that works. It's a pity the spy mode isn't working correctly but I can live with doing it this way for now.
Best Regards 🙂
Paul Duffy
Thanks Paul 🙂
Now days this method provide almost every element detail ,few month back it was not that much useful and was showing only few elements.
Nilesh Jadhav
Nilesh Jadhav.
Consultant
ADP,India
