Application Modeller does not identify elements in centrix data solutions app
03-09-20 07:18 PM
Thanks 🙂
Paul
04-09-20 02:01 AM
Hello Paul
Have you tried with other Spy methods e.g. AA, UIA, etc? Moreover, try running the Blue prism application with admin privileges (Run as administrator) and see if it makes any difference?
Karan Sareen
Solution Support Engineer
Blueprism
Australia/Sydney
04-09-20 05:23 PM
Paul Duffy
07-09-20 04:49 PM
Click on Identify dropdown button and select Open UI automation navigator from application modeler.
you have to check each element from left side tree element.
You will definitely get your required element.
Please let me know if need any help.
Nilesh
Nilesh Jadhav
Consultant
ADP,India
08-09-20 06:18 PM
Thanks Nilesh, that works. It's a pity the spy mode isn't working correctly but I can live with doing it this way for now.
Best Regards 🙂
Paul Duffy
08-09-20 06:39 PM
Now days this method provide almost every element detail ,few month back it was not that much useful and was showing only few elements.
Nilesh Jadhav
Consultant
ADP,India
