Azure Key vault
HemantKumar_Si1
Does Blue Prism has ability to work with password hashes? We are working on a solution where, our passwords for target/legacy applications will be stored in Azure Key Vault as username and password hash. How do we integrate this for the Blue Prism  Process, to be able to use this username and hashed passwords? Please suggest the approach to implement this. Thanks
RichardLepper
Hi Hemant,
What did you end up doing for Key Vault integration?
Rick
Senior Solutions Architect
Kforce
Any sample solution for this please?
Gayathri S
Application Engineer
DXC Technology
Gayathri S
Check connectors available on the Digital Exchange platform.
Dawid Ochrymuk
Dawid Ochrymuk Manager KPMG Poland
