BP6.7.1 automate.exe crashes while using MapiEx / DtaOLEDB
al2piwo
we face the following problem, we have set up the following infrastructure as part of a Blue Prism release change from BP5.0.24 to BP6.7.1.
Windows 10 Version 1803 - 64-Bit Installation
Office 365 - 32-Bit Installation
MapiEx v2.0.6.0
Access Database Engine provided by Microsoft installed in silent mode
MapiEx and OLEDB work as individual components, as soon as I run both functions in succession, Blue Prism and automate.exe crashes. In Windows Event Log a .NET Runtime Error is listed in both directions. (even if I start first MapiEx send mail action - which is successfully and subsequently OLEDB Object - with crash of automate.exe or if I start with OLEDB which is successfully and subsequently MapiEx send mail action - with crash of automate.exe)
Are there any suggestions from anyone? Seems to be a problem of multi threading caused by .Net?
Jan Piwowarski
Developer
Commerzbank AG
AndreyKudinov
Level 10
I'm not sure about interaction between this two, but using MAPI from managed code is officially unsupported. MS suggests running mapi in a separate process.
You can probably make it work like we did.. for a month or two, then it starts crashing once or twice a week, you give up and migrate to Outlook VBO, SMTP or EWS (or Graph?):
- SMTP is for sending mail only, but that's fine if that is all you need. Using POP3/IMAP for receiving mail is not a great idea imo.
- Outlook VBO is good, but it requires Outlook install and it is still interop. Solid choice.
- Exchange Web Services managed API - it doesnt need Outlook installed or running, works for both on-premise Exchange and Online/365, but ...
"Starting July 19th 2018, Exchange Web Services (EWS) will no longer receive feature updates."
- ...and "the recommended access pattern for Office 365 and Exchange online data is Microsoft Graph instead", but that doesn't work for on-premise Exchange.
I think Blueprism posted some Graph stuff on DX, but we have on-premise install, so I never bothered to check.
p.s. there is also this good library, but commercial license and that also means writing your own VBO from scratch: http://www.dimastr.com/redemption/download.htm
Andrey Kudinov
Project Manager
MobileTelesystems PJSC
Europe/Moscow
