#BPTechTips - Stage Logging and its Stats
Neel1
Hello Everyone - My contribution to #BPTechTips is on stage logging.
Most of us know that there are number of way to modify the stage logging.
User can open Studio :- Edit>All Stages and can set  logging to enable/disable/error only.
OR
User can also control it from System>Resource>Management>Right click on resource and calibrate logging as per need.
Today- i want to share one Blue Prism feature which can give us number and percentage of stage that are set to high logging.
For that, You have to go System>Report>Logging>Click Generate>Give a path and depending on your count of Process and object, report will be generated sooner or later and will be saved in path mentioned.
This will help to see how our Process and object are doing on Logging and one can take necessary action on that.
One of sample report looks like this :-
Neeraj Kumar
Software Engineer
0 REPLIES 0
