Best way to migrate a process to a different RPA instance, without loosing Dashboard data
Ajay_RambabuKol
There is a requirement to change the RPA windows platform. Hence the current Process is to be moved to the new RPA instance by having a new DB instance. Importing the process release file will not alone be the process for the movement. We need to even retain the Blue Prism dashboard statistics data to the new RPA setup. What are the methods possible to move the process to a new RPA setup without loosing Blue Prism dashboard statistics data?
Consider moving the old DB into the new infrastructure, then run the upgrade script. That way all your processes and data will be carried over.
