Blue Prism Load Balancer Connection Error
23-10-21 04:54 PM
Hi All,
I am getting following error while connecting to app-server from runtime resource :
Could not connect to https:<someservername:8199>/bpserver. This could be due to the fact that the server certificate is not configured properly with HTTP.SYS in the HTTPS case. This could also be caused by a mismatch of the security binding between the client and the server
Configuration Details:
Siddheshwar Kore
- BPv7.0
- Two Load Balanced App servers
- WCF: Transport Encryption
- Load Balancer set to use SSL Passthrough
- Same SSL cert applied on two app servers
- Same configuration in both app server (Encryption schema etc. except binding address which is FQDN of each app server)
- CN of SSL cert: bluprismprd.somecompany.com
- FQDN of Load Balancer: bluprismprd.wip.somecompany.com
- Runtime Resource is configured to connect to Load Balancer VIP FQDN (bluprismprd.wip.somecompany.com:8199)
Siddheshwar Kore
5 REPLIES 5
26-10-21 09:06 AM
Hi Siddeshwar,
Please try with End to End SSL on load balancer (you should install the same certificate that of the application servers in LB as well) and Runtime Resources must be configured using /sslcert flag along with the thumbprint of the specific SSL cert which must be deployed locally on the runtime resource. The certificate should be deployed to the machine certificate store, not a specific users store.
Jerin Jose
Technical Product Owner
EY
*"If you find this post helpful mark it as best answer, .*
Jerin Jose
EY
27-10-21 12:14 AM
Hi Siddheshwar,
Looking at your configuration, the common name (CN) on the certificate (bluprismprd.somecompany.com) does not match the FQDN of the Load balancers VIP (bluprismprd.wip.somecompany.com). Please reissue the certificate with either the CN or a Subject Alternate Name configured as bluprismprd.wip.somecompany.com, then reapply to the BP server configurations on each of your application servers.
Ryan Andrews
Platform Consultant
Australia/Brisbane
Ryan Andrews
Platform Consultant
Australia/Brisbane
01-11-21 04:10 AM
Hi Ryan, thanks a lot. Even I was suspecting this could be a problem so I added a DNS entry which would resolve the blueprismprd.somecomapny.com. to blueprismprd.wip.somecomapny.com. However the issue persists.
Siddheshwar Kore
Siddheshwar Kore
02-11-21 02:52 AM
@RyanAndrews
Hi Ryan,
After making some changes in configuration, now the error message has disappeared. now I am getting following error:
Increase the timeout value passed to the call to request or increase the sendtimeout value on the binding
May I check how can change the timeout value in Blue Prism Config? Is it even posssible? in LB timeout is set to 60s persistence to 15 mins so LB should not be an issue I believe
Siddheshwar Kore
Hi Ryan,
Siddheshwar Kore
10-04-24 12:49 PM
Im facing the same issue as you reported here.
Could you please let me know the steps which performed to resolve the issue.
Sheela
