Blue Prism and Integration with AI
PankajNaik
Hi Team,
How can Blue Prism integrate with AI (Artificial Intelligence )
Please request you if anyone can give me small example with process / objects  and give code for understanding.
Pankaj Naik
[email protected]
Pankaj Naik
ashish.easow
Hi Pankaj,
If you are looking for a basic ML example, you can look at different samples in the Dx.
I created one which was a bit complicated involving python here - https://digitalexchange.blueprism.com/dx/entry/3439/solution/pre-trained-sentiment-analysis
But you can search for simpler ones.
regards,
Ashish
Ashish Easow
Senior Consultant - Professional Services
Blueprism
