Blue Prism control room scheduler
PedroGouveia
Good evening
Recently I've been trying to run robots using the scheduler and created a new task to run a robot hourly, but it didn't work, is it even possible with Blue Prism Learning Edition?
Thank you
Pedro Gouveia
NicholasZejdlik
Level 9
In order for the scheduler to work, the Blue Prism Server application must be running. I am not sure if that is included in the learning edition. Check the directory where Blue Prism is installed, and run BPServer.exe if you have it. Once that is set up and running, your schedules should begin executing.
Nicholas Zejdlik
NicholasZejdlik
Level 9
Nicholas Zejdlik
I Did have the BPServer.exe, but it cannot be used with the Education License, thank you
Pedro Gouveia
