You could use the Work Queues to hold the data. In First Run, update the queue item using Set Data action of Work Queues BO, Update the Tag with something to identify the required item in the next run and unlock the item. In next run get the item from queue by applying the Tag filter in Get Next Item action.
Hope this helps. Cheers!
Rafeeq Mohammad
Automation Engineer
Q4 Associates Ltd
#MVP
