BluePrism 7.0 AA Spy mode issu
23-09-23 04:33 PM
Hi All,
Recently I developed a code for a chrome automation using AA spy mode. Today all of sudden the Spy is not working and none of the elements are getting highlighted as well using AA mode in my machine. However in another machine the AA mode works. Can anyone suggestion any resolution for this? I tried to restart the machine, its still the same.
Note : The Blue prism version is 7.0.
Prathamesh -
24-09-23 08:31 AM
Hello Prathamesh
Could you give more details?
Informations:
- Browser extension version
- Manifest version
- Browser version
- Did the problem arise after a browser or machine update or was it a clean installation?
Possible solution:
- When I had this problem, I downgraded the extension and browser version (based on the machine on which the spying was running), this could be a way to go.
Leonardo Soares
RPA Developer Tech Leader
Bridge Consulting
América/Brazil
25-09-23 09:57 AM
Hi The chrome version is 117.0.5938.92
Blue Prism 7.0.1 Browser Extension, not sure on how to check manifest version though.
On analysis it seems chrome as been updated to recent version, other than that i don't see anything. Any thing on this will be helpful.
Prathamesh -
25-09-23 02:10 PM
Hi Prathamesh
Worth checking this thread:
UIA Spy method not working | Community Chat (blueprism.com)
Refers to UIA but also affects AA I believe and the Chrome update is the issue. There is also a suggested solution.
Kirk
Kirk Russell Senior Robotics Developer
NHS Dorset
