04-06-20 02:39 PM
10-06-20 03:14 PM
The issue has been addressed in Blue Prism version 6.6 – this can be confirmed by reviewing the "Fixes and Minor Improvements" section of the Release Notes for 6.6 and viewing the entry for BG-3786. The Release Notes are available here:
Blue Prism Release Notes 6.6.0
If you are unable to upgrade at this time, there is also a workaround available.
When you create a new Action stage, manually enter a value for the 'Name' field before selecting an object and action:
If you have populated the 'Name' field first, then you should not see the same delay while selecting an action from the 'Action' drop down option shown above.
