Hi
@vinod chinthakindi,
It's not clear to me, from the screenshots, whether Power Automate is actually sending those credentials as HTTP Basic Auth. Give the 401 response, I'd say probably not. You might try running Fiddler or Wireshark to capture the network traffic. Then we can see the actual HTTP request along with the headers and see if there is an Authorization header included.
Is you Blue Prism environment running in an Azure instance or on-prem? Something else that could be happening is simply a firewall blocking access to the BP instance from the outside world.
