08-09-25
		10:59 AM
 - last edited on
		08-09-25
		05:34 PM
 by
			Michael_S
did any of you guys notice issues while automating processes in Chrome version 140.0.7339.81?
The latest version was released at the beginning of September and till then we are struggling with unexpected issues.
Processes are freezing on various stages e.g. writing or click a field. We disabled all popup like autofill or translation prompt, as a blocking factor, but they still hanging.
We noticed when a process is a warning state already, and we open VM, then suddenly it works again. And yes, we are sure that the screen does not lock etc.
Thanks!
L
MOD EDIT: We've locked this thread and moved the discussion to this post. If you're impacted, please come and join us there for the latest information.
08-09-25 12:07 PM
Hi @l.kiciak
we're facing the same issues. A lot of our UIA elements, browser mode elements are failing to identify while running, but are identifiable through the app modeler.
Best guess there was an Edge & chrome update late last week. It seems the issue is with updating of browser. Lets wait for the solution from community.
08-09-25 01:07 PM
Hi, I can confirm the same for several of our clients using UIA elements or download dialog window in MS Edge. The temporary resolution was to downgrade it to version 139.x which works well.
Zdenek
08-09-25 01:14 PM
Hi Zdenek,
thanks for the hint!
Unfortunately, downgrade is not an option in our case. Would be nice to know, what is causing the issue.
Best,
L
08-09-25 01:19 PM
