Code Or Libraries Related Issue
Hi, I am facing some code issue like compiler error on VM(Sesseri03551.ss.sw). I put much effort to remove this error but not removing. Please help me. When i am running code on different VM(Sesseri03546.ss.sw), the code is perfectly running. But the same code on this VM(Sesseri03551.ss.sw.ericsson.se) not running. I think Libraries are not mapped on VM. Screen shot are attached.   Thank You
It's probably due to some difference between the VMs if one can find the references and the other cannot.
