Completed Items marked in control room execution as exception: Automatically set up exception at CleanUp
04-10-17 10:34 PM
Hi all,
We are running a process which marks all items completed correctly (and they appear completed when we look at the queue), but when the process ends and results completed, all items are marked as exception, with the exception reason "Automatically set up exception at CleanUp".
There are no exceptions or errors in the process log, and when we run the process in the studio instead of running it at the control room, this error does not happen.
Can anyone help us with this issue?
Thank you very much
05-10-17 11:49 AM
Hi Javier,
Most of the times when you run your process from Control room problem arises because of insufficient wait stages..In your case may be all Items remains locked till the process ends (may be because something is wrong before Mark Completed action ) and finally as they are not marked as completed or Exception ,they are automatically marked as exception by BP...
for testing purpose in process stud. set Debug speed to Fast and check whether it is working properly...
