Connection Failed SQL Server Blue Prism Hub 4.7
tono0582
Is there any way to install Blue Prism Hub 4.6 or earlier without using SSL Encryption CA? I need to run some tests in my test environment to load data into the Blue Prism queue through API. Thank you in advance!
Blue Prism Enterprise v7
KodiSrihari
Level 9
Hi @tono0582
As per the Document the SSL is a Pre-requisite , That may be Self signed or Organization provided.
During the Installation it will ask for the SSL Certificates. May be for the Dev, POC level you may go with Self signed certificates on SSL.
If you are Using same DB Server for DEV and Prod , facing any challenges/ difficulty if Enable SSL. You may go with the Force Encryption Disable while Enabling the SSL. As it won't change or Effect more on All DB servers.
Please find the below URL for the Self signed certificates.
https://docs.blueprism.com/en-US/bundle/blue-prism-hub-platform-4-6/page/installation/install-hub-downloads.htm
