Credential Management
Need to setup a process to reset the password after expiry. Can anyone help me in this regard ?
Deep.Shah
Hi vankayalapati, There was one such need for us as well, to change passwords after some-time, else they expire. But, since we were using Login Agent, there is a process to change the password which we use, and set a new password before it expires.
rj.latherow
Any idea if this can be leveraged for a password credential that has nothing to do with windows? We are using the credential manager to store web based app passwords as well, and need to be able to update them from a process. I can't find the part of Login Agent that updates the BP credential store...
The 'Internal - Credentials' business object has 2 methods to update a credential - 'Set' and 'Generate and Set'. With the former you provide a password and with the latter a random password is generated automatically. To automate an application password change you would need to model the 'update password' steps a user would perform, then after the application has been updated, change the BP credential accordingly.The Login Agent object is not related to the BP credentials store. The Login process makes use of the 'Internal - Credentials' object, but only as a means of obtaining a Windows user name and password to give to the Login Agent object.
