Debug 'Step Over' Jumps to Wrong Stage
manas05
Hi everyone,
I'm working on Blue Prism v7.3.1, and I’ve run into an odd behavior in Studio while debugging.
When I use Step Over during process execution, the  pointer randomly jumps to a stage with no logical sequence, It makes line-by-line debugging a bit disorienting
This wasn't the case when I worked with BP v6.7 and earlier — Step Over used to move strictly to the next logical stage in sequence.
Blue Prism Enterprise
Has anyone else experienced or have found workaroundfor this in 7.x...?
Hi @manas05
Have you observed this issue on any other machines, or is it happening only on yours?
How often do you encounter this problem?
Best Regards,
Sayeed Bin Abdullah
Hi @SayeedBinAbdullah
I've tried multiple machines, and other team members have observed the same behaviour.
Frequence of issue, whileI debugging, when I navigate to other stage and come back to debug focus stage and step over. At the moment havent nailed down the exact reproduceable steps, but I am sure that these are general conditions.
A correction, BP version we have is 7.2.1.7446 64 bit with .Net version 4.8.4790.0
