Does Blue Prism support mobile Device automation?
ArjunBaiju
I would like to know , is there anyway to do mobile device automation using Blue Prism? Thank you.
Can you give some more info on what it is you are trying to automate? There are things such as phone emulators and I guess those could be automated although this would most probably be done with surface automation techniques, not sure if these fit your needs though.
I agree with Sebastien, we need to know more. Are you talking about using a mobile device as a work source input device to feed a Blue Prism process, are you talking about interface with mobile device apps? Blue Prism is a .NET windows platform - so you will be constrained by that.
