Dynamic Input Dialog Boxes- Assisted Automation
vivek.kumar.goel
ManojDhamrala
Hi Vivek,
I appreciate for sharing this post it's helpful.
I have a question. If the automation is running in some virtual machine then how can we implement these in assisted automation?
Manoj Dhamrala
Associate Consultant
I developed those for a client, where they had the assisted infrastructure and OTP requirement for login.
So I used this form for capturing OTP only.
The client had a DESKTOP screen, where he/she will login to before starting the bot.
The bot does everything but then waits for the OTP. The user manually enters the OTP in the popup, and clicks OK.
The bot takes over from there.
You can also think of different use cases.
Vivek Goel
RPA Architect
Asia/Singapore
+6594554364
https://www.rpatools.com/
