29-08-22 10:37 AM
29-08-22 01:47 PM
29-08-22 02:28 PM
In addition to Johan's answer I would recommend using the collection manipulation object for question 4. It can be found Digital Exchange or with the link below:
https://digitalexchange.blueprism.com/dx/entry/3439/solution/utility---collection-manipulation
It gives you a lot of benefit in terms of working with collection without knowning the specific codes.
30-08-22 04:56 PM
02-09-22 01:31 AM
Hi Varun,
On 1 and 2, the only way I am aware of is to use the Tracking Id feature found in latest versions of Blue Prism. For v6, it is a bit tricky as you must disable fixed port mode, and that itself may lead to some issues.
In addition to the above, there are also some other considerations to think of:
