Error:- Process owing Foreground window
AbhinavJanga
Hi All,   I am trying to run a process from control room in a VDI. I have disconnected the video and tried to trigger the process from the other VDI. The Process started running, but stopped within a minute saying process owing foreground window. Note:- The run mode of the process is Exclusive.   Any help would be appreciated.     Thanks, Abhinav
Ravindersaini
Level 7
Hi, Refer below link; https://help.blueprism.com/1136103652  Regards, Ravinder Saini
AbhinavJanga
Hi Ravinder,   Thanks for the response.   I am getting this error with Activate stage itself. Is there any other alternate way to activate a particular application.   Thanks, Abhinav
ChrisS
Hi Abhinav,   Did you solve this issue? I am having a similiar problem at the moment
If 'I disconnected the video' means you have been accessing the VDI by RDP, then you will have a problem with Activate. When you disconnect RDP, the desktop of the VDI is destroyed but the machine (and BP) is still running. This means a process wanting to use Activate (or screenshots or click) will have problems, because the desktop is not there. Confusingly, when you reconnect RDP to investigate, the desktop is remade (like the light inside the fridge). If you must use RDP (and it's not recommended) then you should log the VDI out and back in again using Login Agent. See https://portal.blueprism.com/documents/v6-data-sheet-remote-access-tools
