Error with Script Execution VBO
14-09-21 08:25 AM
Hi!
I am trying to use the object "Script Execute VBO" by passing the following data to it:
- ScriptEngineFilePath= C:\\Users\\jvivespa\\AppData\\Local\\Programs\\Python\\Python39\\python.exe
- ScriptFilePath= C:\\HelloWorldPy\\
When I run it, Blue Prism "does not respond", Blue Prism stuck.
Do you know what could be happening?
Thank you very much.
14-09-21 11:01 AM
Hello Jose,
By running do you mean Debug Mode or from control room(Calling action in process level via object)?
Best Regards,
Ved Sengupta
Deloitte India (Offices of the US)
Bangalore | INDIA
*If you find this post helpful mark it as best answer*
14-09-21 11:07 AM
Hi Ved Sengupta,
in debug mode.
Thank you for your ankwer!
in debug mode.
17-09-21 05:00 AM
Hello Jose,
What is the version of python pip you are using?
can you try with a power shell script and see if you are facing the same issue?
Any dummy script might do for us here to understand.
Also, I have seen this happening sometime with normal traditional actions also.
Try running the process from control room to check if you face the same issue!!!
Best Regards,
Ved Sengupta
Bangalore | INDIA
26-09-21 01:02 PM
By looking at this all looks good to me ! For the script engine file path instead of pointing from appData folder can you point the python exe from Program Files(x86) ?
Can you please share the python code too please ?
Vipul Tiwari
Amazon
