Export a Tested Model
YanierkisArmari
Hi.
We are testing our Decipher document definition with different batches and, after that, we have tried to export the tested model but we only have the document definition, not the trained model of the testing. We need to export the model because we are going to work in another machine.
We have been looking in Blue Prism documentation but we didn't see very much about the issue.
We also look at the community of Blue Prism and we found this:
Can we Export ML model somehow which is already trained? | Decipher (blueprism.com)
In the threads it´s said the in the new version they solve the problem, we wan't to know if it's related with our problem and if it's solved for the new versions of Decipher.
Yanierkis Armario
BenLyons
Hi Yanierkis,
What version are you currently using?
Can you see the "Capture Models" option on the Admin tab?
Ben Lyons
UK based
