Facing issues with checkbox in Chrome
MayankGoyal2
Level 8
We are facing intermittent issues selecting a checkbox on Chrome. Sometimes it checks it and sometimes it doesn't. Also checking if checkbox is selected returns true at times even when its not checked.
The logic seems correct because it works many times and fail times. However when it fails, even retry doesn't solve the purpose.
Is there anything else we can do to make it more stable. Spying is done in browser mode.
BP version is 6.4 hence we have to use Chrome extension 1 with it.
Mayank Goyal
Hi Mayank,
I suggest using the Activate Application action and then use the Focus action navigator before you select the checkbox action you have.
Hossein Azimi
Customer Support Engineer, APAC
Sydney NSW
