Global send Keys issue
_Amlansahoo
Level 11
Hi Folks,
I want to send a text using Global send keys which is having Space in start and End.
For Example:- I want to pass " Last 14 Days " , So space is there in the beginning.
So while sending instead of taking it as text, blue prism trying give Space Keystroke so my page is getting down but text is I am unable to Select from drop down.
Any suggestion or any one faced similar issue.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
joakimeklund
Hi Amlan,
Would it work with this as input parameter Chr(32) & "Last 14 Days" & Chr(32)?
/Joakim
Joakim Eklund
Senior RPA Developer
Swedbank AB
Europe/Stockholm
I did not try. I will try and let you know.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
SaumitraSharma
Hi Amla,
In the value press Space from the keyboard inside the double quote for sending the space as send key it will work. so your value should be like " ".
Saumitra Sharma
Consultant
EY
Indian/Christmas
