HTML Email body
ShashiK_R
Is there any way that I can send/read emails in HTML format using MAPIEx?
Actually it is possible and requires small changes with encoding inside MAPIEx BO itself.
Hi , Please describe the changes required inside MAPIEx BO.
ShashiK_R
I was trying to send HTML formatted emails in C#. Code looks good and works outside of BluePrism. But I'm getting error within BluePrism. Is there any separate settings that needs to be done? Error: ""Internal : Could not execute code stage because exception thrown by code stage: Failure sending mail.
JorgeFernandez
Hi, Could you please describe or share the changes needed in the mapiex object for HTML in the body? Thanks KR Jorge Fernandez
