Hover over a region and click on the elements
21-10-20 03:29 PM
Have you come across any scenario in Blue prism where we need to hover over a region and then some icons are displayed and we need to click on any one of them?
Actually the icons that appear after hovering do not have a fixed region on the dashboard, depends on the position of mouse pointer and the icons are displayed anywhere around that region.
Please help me with this.
Thanks.
Nikita Singh
Thanks.
Nikita Singh
5 REPLIES 5
21-10-20 03:53 PM
Hi Nikita,
What type of application are you automating, and what spy modes are you able to use?
With browser mode in 6.9, there is now a Hover action included in the navigate stage, but you would need to come up with a different approach for region mode.
Patrick Aucoin
Senior Product Consultant
Patrick Aucoin
21-10-20 04:12 PM
Hi Patrick,
It is a Tableau dashboard which I can access through a URL.
I am able to spy elements using browser as well as region mode.
I have identified the region and I am able to successfully hover over it.
But When I try to capture the hovered element that shows up only after hovering, that element is not being captured.
Nikita Singh
Nikita Singh
22-10-20 02:45 PM
Hi Nikita,
Please select Anywhere from region mode.
I hope it will work you.
Nilesh
Nilesh Jadhav
Senior RPA Specialist
Nilesh
Nilesh Jadhav
Nilesh Jadhav.
Consultant
ADP,India
Consultant
ADP,India
22-10-20 04:05 PM
Hi Nilesh,
Sorry, but I didn't get you.
Can you please elaborate?
Thanks.
Nikita Singh
Thanks.
Nikita Singh
30-10-20 11:39 AM
Hi Nikita,
From Blue prism region editor screen you have to select position as Anywhere ( You will get Fixed,Relative,Anywhere from dropdown)
click apply and ok.
Nilesh
Nilesh Jadhav
ADP
India
click apply and ok.
Nilesh
Nilesh Jadhav
ADP
India
Nilesh Jadhav.
Consultant
ADP,India
Consultant
ADP,India
