How do I align steps in studio, instead of manually dragging them?
TathagatVerma
While designing an automation for a process, is there a way to auto align steps or diagram tools in a proper or organized instead of having to manually drag them every time?
TomBlackburn1
Level 7
Unfortunately not. I guess this could be a nice feature - not sure how it would work - but I guess the free placement of elements makes it easier in some respects to align as you see fit, as in more complicated designs the flow might not specifically be linear.
Keep it tidy as you build your flow would be my suggestion! 😉
