How do we measure Uptime of resource PC?
BasavarajMasur
I have a process that runs on 10 machines. I need to measure the Up-time of the BOTS. In this case I have ensure all the 10 bots are connected to resource for 100% uptime.
How do determine how long the Resource PC was available as idle in control room?
Basavaraj Masur
MaxElopre
Hi Basavaraj,
I suggest that you please contact support@blueprism.com and ask for the "Blue Prism License Utilisation Script".  This could help you in calculating the idle time of your resources.
Best,
Max Elopre
Technical Consultant
Chicago IL
