How to Delete Debug Resources using SQL Script?
David-Dinh
IMPORTANT:: LATEST VERSION IS 2.3.  MAKE SURE YOU HAVE THE CORRECT VERSION AS COMMUNITIES DOES NOT ALLOW REMOVING ATTACHMENTS.  PLEASE SUBMIT A TICKET IF YOU CAN NOT FIND THE FILE ON THIS PAGE.
Here a a script you may use to remove debug run time resources.  This will aid in reducing the number of unnecessary queries' being generated by RR.  For more info on this, please see the KB Why is my Control Room unresponsive when viewing Resource Manager?
The script will remove debug resources from the database and its dependent tables.
IMPORTANT!!!!!
This script was not created or supported by BP product team and is NOT officially supported.  This script was created to aid BP users and carries no warrantee.  This should only be used by a qualified DBA or SQL Developer.
David Dinh
Software Support Engineer
America/Chicago
Walter.Koller
Level 11
Thanks for the post.
The link opens a login page but without the possibility to register. Does my Blue Prism portal login work?
Walter Koller
Solution Manager
Europe/Vienna
AnonymousMember
Level 10
This post was removed
