How to Press SAP Element GuiStatusPane
jamesli000
Hi Everybody
     I spy the SAP element type as GuiStatusPane. But when i navigate it, there are no "Press" action in it. Anyone know how to press this icon?
James
James Li
Nandhakumar
Hi James,
Can you please share what other options you get when you use the above mentioned element in Navigate stage, so that i can suggest you.
Also, did you try spying the same element using any other spying mode, if possible?
Nandhakumar C
Technology Consultant
SimplifyNext Pte Ltd
Singapore
Dear Nandhakumar
     Many thanks for your help.
     I found I spy to the wrong element. The correct element is GuiButton and it works.
James
James Li
