How to Read Password to verify it is entered correctly?
02-04-18 09:33 AM
Hi!
As password fields are masked usually ****** (or with dots) , how do we read the password entered to ensure that it has been keyed correctly before the robot pressed the "Sign In" button?
Thank you!
02-04-18 04:04 PM
Do you write the password via a write stage to a Win32, HTML, or Active Accessibility element?
Then no need to verify; the data you entered via the write stage will be the data present.
